Ebike thoughts
Geek
Hi,
I rode a friends ebike today - 18650 powered running one of these. 13s20p.
I was curious if I should try 12s, easy to charge, to 6s lots on my RC charger.
Has anyone had much to do with these cheap ebike motors? They have plenty of power, but I was wondering how long to expect the motor/controller to last?
I have something similar, a 48V 500W rear wheel hub motor running on 12S. Had it for a couple of years now and still going. The hand grip twist throttle is getting a bit wobbly otherwise it's still good.
Geek said:
Hi,
I was curious if I should try 12s, easy to charge, to 6p lots on my RC charger.
The price is so good you can hardly go wrong.
I'm considering getting one to make my bafang giant a dual motor. :D
By my calculations I would have to go 20p to supply the 20a current that would be required - for 1000w. However for starters I might limit to 5p, and only 250w. However, I cant see using 1kw for anything but the shortest of bursts, if at all.
Being laptop batteries, I don't feel comfortable pulling more than 1a per cell.
