Glenn Eisenhut
- Jan 22, 2018
- 1
Hi there - I have recently built 3 18650 cell packs as a bit of an experiment. Each pack contains 40 cells, which have all been tested.
Each pack has been fully charged and connected in series to achieve the desired ~12V.
This weekend I purchased a pure sine wave600W inverter that was on special at Jaycar - the unit also included a charge controller. When I connected the inverter, an under-voltage alarm sounded and the inverter wouldn't start. I checked the specs of the input voltage -8 to15 VDC and measured the pack voltage at the terminals on the inverter which measured just under 12V.
No matter what I tried, I couldn't get the inverter to start.
Assuming the unit was faulty, I returned it (for a cheaper unit that didn't include the charge controller). This unit will also not start - it just sounds the under voltage alarm as per the previous unitand fails to start.
I'm at a loss here - the pack voltage is def in range -at the input terminals of the inverter it's measuring atjust under 12V.
Any ideas folks?
Any ideas folks?
