Jeremy Choy
- May 10, 2017
- 60
Unforeseen circumstances came up and have to sell my cells.
Untested over 3V $0.50/cell <100 left
Tested 1400-1600 $0.50/cell <125 left
Tested ~1700-1800 $.75/cell <100 left
Tested 1900 $.85/cell -QTY 120 Left
Tested > 2000 $1.00/cell -QTY 240 left
Min. $20 order + shipping
Note:markings on cells are based on tested down to 3.2V. I will by default add 100mah so you will be accurate mah.
Tested to max 34.5C at 35C my system tells me to throw them away
Testing procedure: Charge cell. let it sit for 1 week. If >.07 drop gone, must be over 4.05V. then onto the MAH test without recharging back to full. This should yield above Mah rating written on cell
- Dischargers was tested with the same cell. All chargers within 50-75mah of each other. Most are less than 25mah.
Shipping is normally between $15-25 for Canada.
email best way to contact: tatajer is mygmail email address.
