garolittle
- Oct 27, 2017
- 100
I need to connect the wire shown in the first photo below to a shunt that will be mounted on the go kart.Since the wires (12 AWG) will be mounted to a shunt, I need to addamp ring terminals to each end of the wire prior to connecting it to the shunt. I am going to show my ignorance by asking this question but I would rather be embarrassed on the Internet than run the risk of electric shock. Is it safe to cut the wire at the point indicated in the picture below and add the the amp ring terminals (either by crimping or soldering) and then connect the wires to the shunt? Thanks for any advice anyone can offer.
I should have included more details (sorry about that). The go kart project consist of the following:
48V 1000 Watt Brushed Motor with rated current of 26.7 amps
48V charge controller
14S9P batteries using Samsung INR18650-25R 2500 mAh 18650 cells (connected with spot welder using pure nickel strips)
I added a 35 amp fuse (rated for up to 58 volts) and I hope to hook everything up to the go kart soon. Thanks to those on this forum who have provided advice to me. I really
