$1.6 per cell NCR 18650 GA 3500 mAh 92%-98% LIGHTLY USED
SolarSolutions
These cells are in excellent condition, testing at 95% (or higher) of the manufacturers rated capacity.
Please take note, these cells were extracted from brand new battery packs, so they have spot weld marks and sometimes small quantities of leftover nickel from the welds on the positive and negative terminals (see pics). This does not affect the cell's performance in any way, you could spot weld or solder over them or remove very easily.
You are getting brand new quality & capacity, for the price of "used" cells which would normally have noticeably decreased capacity.
Most of our cells still test over their rated capacity, though to be on the safe side, we say 95% or higher.
Besides the spot weld marks, they are otherwise "new" in performance and quality
Rest Assured, Always 100% Authentic, GUARANTEED!
SHIPPED PRIORITY MAIL
SAME BUSINESS DAY SHIPPING
PACKED BY A CERTIFIED PACKAGING EXPERT
SHIPPED FROM USA
Below are full specifications, fell free to ask questions that weren't covered here:
Official specifications:
Rated capacity: 3500Ah
Minimum capacity: 3350mAh
Typical capacity: 3500Ah
Nominal voltage: 3.63V
Discharge end voltage: 2.5V
Charging current (Std.): 1.675A
Charging voltage: 4.20 +/-0.03V
Charging time (Std): 4.0 hours
Continuous discharge current (Max.): 10A
Internal resistance (AC 1kHz): <38mOhm
Cycle life: 700 cycles to 70%
Weight: <49.5g
Operating temperature: Charge: +10 ~ +45C, Discharge: -20 ~ +60C
Storage conditions: less than 1 month: -20 ~ +50C, less than 3 months: -20 ~ +40C, less than 1 year: -20 ~ +20C (80% capacity left)
Here is an in-depth data sheet about the cell and it's testing and origin.
https://lygte-info.dk/review/batteries2012/Sanyo NCR18650GA 3500mAh (Red) UK.html
No ultrafire scam stuff, these are honest, hardworking 3500mah cells.
