- Sep 25, 2018
- 2,063
@kje
ICR and INR cells of old were generally quite easy to differentiate. Not so much any more.
ICR chemistry does have a greater energy density compared to other chemistries but at a higher risk rate of "explosion" so it has been said.
The shift then to INR/IMR "safer" chemistries is a noticeable one
The amount of chemical doping that goes into today's batteries is phenomenal
Some manufactures will identify the ICR and INR chemistries in the part number. Some of them in there spec sheets.
Some of them not at all.
Notably any very low IR cells as in the Samsung INR18650-20S which measures at ≈ 8mΩ,. or the Sanyo UR18650RX 25mΩ factory spec, but consistently measures at ≈11mΩ. are defiantly INR
What I find is that if you have at least 20 cells of the same manufacturer and part number, when you check IR and the 20 cells have an IR of 35mΩ to 40mΩ and C/D/C at 1A results being close to 100% SoH that would be a good IR for that particular cell. Chances are its an INR.
My powerwall is basically built with LGBBM261865, LGEBM261865, LGFBM261865, and LGGBM261865 considered INR18650M26 or
for short LG M26.
The LG LGGBM261865 and LGGBM261865 had a min of 32.61mΩ to a max of 37.58mΩ out of 1172 cells and that is according to LG an INR cell
The LGFBM261865 also a "M26" had a min IR of 35.06mΩ and a max of 51.64 out of 1225 cells
Manufacturer Spec for the LG M26 is ≤60mΩ
The Samsung ICR18650-26F cells obviously claim ICR and the IR was min 50.3mΩ and max 55.59mΩ out of 1120 cells
Manufacturer spec for the Samsung is ≤100mΩ.
So you see there is a fine line between ICR and INR chemistries.
My excel database allows me to easily compare "know" manufactures cells so I can attempt to understand a bit more.
It is in excel format a work in progress but if you want to download it it is here.
for short LG M26.
Cell DBA.xlsx
1drv.ms
