- Sep 25, 2018
- 2,079
Liitokala has max 1A
This is true only for charging. Unfortunately discharge is max at 500mA so not a good test of V drop.
Also if you depend on the LiitoKala for IR measurements it is not accurate at all. It is a makeshift DC IR reading extrapolated with some programming trickery and tries to take into account the contact resistance of the sliders. The only way to accurately test IR is with a 1kHz AC impedance meter such as the YR1035 or the RC3563 or equivalent. Check out 4 wire Kelvin measurements.
Also look at manufactures cell spec which indicates all measurements are to be performed with a 1kH Impedance meter
"The impedance meter with AC 1kHz should be used."
Most will state that initial internal impedance measured at AC 1kHz after standard charge. ( Initial internal impedance is ≤ XXmΩ )
Please see an extensive review of the LiitoKala here:https://lygte-info.dk/review/Review Charger LiitoKala Lii-500 UK.html
Quote from the review
"Fast test Li Ion (Discharge & charge)
This test measures the charged capacity. It might be a fast test, but it takes about 10 hours!
The possible discharge currents are 500mA and 250mA, they are selected depending on charge current:
1000mA and 700mA charge current will select 500mA discharge current.
500mA and 300mA charge current will select 250mA discharge current."
Also Vdrop is measured in a different way You measure the voltage of a circuit at rest i.e. a battery or cell with no load.
You add a load such as a 1Ω resistor and measure the voltage of the cell during the load, that is your voltage drop. Vdrop is not measured over time but at the moment of the application of the load.
Example
Cell at rest Voltage 4.0V
Cell with 1Ω loads3.74V
Vdrop is 0.26V
