kje
- Apr 12, 2022
- 275
Thanks.I wonder if a reptile heating pad would work better for direct contact to the batteries? I think they have their sensor built in, so it regulates the temperature quickly. (Not sure about this though.)
You could experiment with the placement of your sensor (maybe closer to the pad). Thanks for posting your journey... I'm watching closely, cuz I want to have heating and ventilation cooling when I get my battery together.
Btw, those temperature controllers work great for vide sous cooking. I use one hooked up to a slow cooker... Amazing steaks from lower quality meat! Perfectly cooked every time (you do need to sear it after though, but that's quick and easy.).
The steak looks very good.
The original leaf battery had some thin aluminium plates close to the heating pads. I'll use the plates between my battery and my 48v heating pads so it spread the heat and the pads are not in direct contact with the battery.
