OffGridInTheCity
Moderator
- Dec 15, 2018
- 2,713
Slight clarification. The OP asked about a panel config rated for 21.7a - e.g. 2p. But the charge controller unit has a 18a max input. I'm not saying the panels would produce more than 21.7a but that they could produce up to 21.7a if requested by the MPPT algorithm. Even 19a is 87% of 21.7a and is higher than the18a max the unit gives.
I'm guessing that the built-in MPPT algorithm will try to maximize power but is not so smart as to be 'aware' of the unit's physical limits. Thus, I'm speculating that I personally wouldn't parallel my strings knowing the amps could exceed the max input amps explicitly given for a unit.
