Stefanseiner
- Apr 16, 2020
- 79
Yesterday I tried to build a mounting system as HB uses. First idea: to find a manufacturer who can build this and uses the CAD files HB provides in his thread
but then I decided to build it for my own out of an old 2mm metal plate
first I cut a template which I can use for the plasma cutter
it's my first work with the playma cutter, so results ar far away from perfect...
...but much better then with a angle grinder
this will be the boddom part of the mounting plate
for the top part I build a second template
some work left for the angle grinder. Rounding the edges and grinding the metal slag
I will not use a single plate but four parts because I will build up a 16s100p system and therefor a single metal plate would be very huge
about 5 hours later
drilling some mounting holes
because I don't have a brake press I bend the brackets with a hammer
sits and fits
ready for painting
I am using metal protective paint in anthracite...
...with some "hammer blow effect" (don't know if this is the correct term in English)
state of yesterday evening, now the parts will have to dry and after christmas it will going on
about 5 hours later
sits and fits
ready for painting
