18650 Garden-Powerwall with 50KWh in Germany
Stefanseiner
the last two weeks I finished my powerwall project. On the ToDO list:
28 batterie packs 60p
At the end it's more effort then the bigger 120p packs because of twice of the amount of busbars
I solder the fuse wire in one piece and at the end I cut the unnecessary pieces
almost ready
just need to solder the fuse-wires to the busbars
next step: balancing all the packs
pretty dangerous so close together, I do recommend not to do so
for me it works well but I_ve done this just several times
on the other side there are sitting the 120p packs, but they need some time to balance too
after 48h of balancing the 60p are balanced and ready for installation
they will support the 11KWh system at the pigsty
all wires are 16mm² as well as the busbars
I decided to take the BMS plate out again and make a modification
I want to add a external voltmeter to the locker so I can see the battery status while walking past the locker without connecting to the bluetooth app, so I have to add a shunt
then back again with the bms and with all battery packs. Two systems with 14s60p each fits into one compartment
next is to customize the bms wiring harness
Stefanseiner
on the right side the two older systems, left the two new with identical capacity
at the app there are four systems now
because the voltages didn't fit there is a huge current at the moment of adding the two new systems to the older ones
4,5V difference.
But it doesn't matter, all cables and BMS are good for 60A continous current
after installing the battery packs I want to add a voltmeter too
the "Dremel" clone works well with the good grind discs from a dental supply
on this picture the display is with default settings therefore the battery status is wrong, you have to manually set the max and min voltage first
last step is to complete the fire safe insulation. Now, the system in the pigsty is finished
next step: the other system at the garden shed
to the already existing two systems of 14s120 there comes another 14s120p
I add a shunt too
it's designed for 200A. Each battery system will be limited to 120A
cables and busbars in 35mm² copper
the bms wiring harness has to be extended
just stuck together, without some cable management at this point
Stefanseiner
here we go, the three systems inside the locker at the garden shed
the moment of connecting
now that it works I can do some cable management
cables for the voltmeter
and the front insulation
now three of a total of four compartments are fully equipped (the smaller locker in the pigsty has one compartement left too)
So, now at this point I finish my powerwall project because weather is getting better and I have lots of plans for my garden.
At the end here are some facts summed up
  • 75KWh of usable capacity
  • 10.800 cells 18650 from used and defective laptop and ebike batteries
  • voltage range single cells: 3,30 - 4,05V
  • voltage range 14s systems: 46,0 - 56,6V (exception: 16s system at the garage)
  • maximum total output power: 16,4KW
  • duration of this project: 11 month -> very first start was in april last year
Thanks a lot to pete for his videos with very good explanations and the possibility to take part of the whole building process, this definitely encourages people which are new to this things to get it on. And for this community too.
I learned lots of things from this YT channels and can't recommend them strong enough to others
