Hi All,
Showing in picture is a 80p 7s. 560 cells
Ave / cell 2259mA
10mm Electrical wire for bus bars with a battery eyelet soldered on the ends.
I used 1 strand of extension cable for fusing. Extension cable is 10 Amp and has 32 Strand. 2 strands dead short on a 1800mA battery burned out
Battery Cable is rated at 176 Ah, 6 gauge I believe. Temporary I'm using a 50 Ah self resetting fuse off the Packs. Showing is a 100 Ah Din Switch for Batteries.
Controller is a PIP3024HSE. 3000W output 24V Nom 142 Ah Battery input.
On the left side is the 240V AC suppling part of the house.
Solar Panels I have 2 at 5.86Ah, 2 at 8.86Ah, and 2 at 9.15Ah. these 2 yet to be installed. Facing West slightly North. This will max out the PIP, rated at 50Ah Solar Charging. on the East side I will install 6 more Panels so I can start charging a soon as the sun appears. The East side will be isolated from the West side via a Din Changeover switch to ensure I do not exceed the Max charge Current of 50Ah. Inline to the PIP is a 50Ah Din Breaker.
Please support my channel. search Adam Cecere
Thank you.
Ave / cell 2259mA
Thank you.
