Must be careful not to make a hotdog with themI have some cells stored in the fridge at 3.7V for over 10 years and they still kept their voltage and are o.k. I agree with storing them at lowest SoC possible but without danger of deep discharge. So for me 3.7 - 3.8 V is nearly the best level for storage. I check the voltage twice a year and rarely find a cell below 3.6 when i start to recharge a bit.
Kinda the same way you did the bms, there. You have a lead that goes between the Pos/Neg of each series group.how would I wire some balance cable for the charger in the case?
Trying this out at the moment, just trying to establish the end pack amp hour rating after charge/test cycle on the hobby charger.Kinda the same way you did the bms, there. You have a lead that goes between the Pos/Neg of each series group.
If you have 6s (with the bms connecting 2s), then you'd put a balance lead between each cell. If you have 12s, with 6 groups of 2s, then you'd put the balance leads between each 2s group. Depends on what series you're going for.
The nickel strip should be able to handle 5A pretty well. So putting a heavier load on them should be fine. Especially if you parallel up the packsI am a bit concerned about that little strip joining each "pack" if I put a decent load on it like my low voltage portable fridge??
What you could do considering they are already in strip packs, is to stack each of the packs together in parallel with polarities matching. Then run a nickel strip across them to tie them together. Or you could just connect all the balance leads together, which would probably be sufficient as all the packs are possibly the same age, roughly(?). This will make it so you only need one major/smarter BMS instead of using those cheap boards.I don't mind keeping this format as I won't need to spot weld anything, just replace the BMS.
