1kw Lithium - Ion Battery (36v 27.9aH 1004wH (lg18650mh1 3200mAh cells)) Lightly used - under 30 cycles
SolarSolutions
Lithium - Ion 36v 27.9aH 1004wH (lg18650mh1 3200mAh cells) Lightly used - under 30 cycles
(Location: Los-Angeles. Will ship anywhere)
Price: $195
Condition: Lightly used, under 35 cycles ( professionally tested)
Manufacturer: Ninebot
Enclosure: Hard plastic and metal hybrid case.
Cell holders: Sturdy, custom hard plastic cell holders with anti-vibration and insulating gray caulk
Connector: Custom Segway-Ninebot connector
BMS: Custom Ninebot BMS. LOCKED. Needs flashing or re-installment of a new one that's non-proprietary. Can be installed at extra charge.
Capacity: 27900mAh 1004wh
Voltage: 36v (max voltage 44v min voltage 30v)
Discharge rate: 90 amps, 135 peak (1000w continuous, 1500w peak)
Charge rate: 6 amps
Charge time: 6 hours
Cycle life: ~800-1200 full charge and discharge cycles (gentle use) or 500-800 cycles if used regularly
Amount of cells: 90
Configuration: 10 series 9 paralel
Cell manufacturer: LG
Cell model: lg18650mh1
Cell chemistry: Lithium-ion
Cell capacity: 3200mAh
Cell connection: 0.2mm pure nickel strips
---Weight---
Without enclosure: 11 lb 4 oz
With enclosure: 12.5 lb
---Dimensions---
Without enclosure: 14.5 inch x 4 inch x 2.8 inch
With enclosure: 16.7 inch x 4.7 inch by 3 inch
Battery meter and charge port are installed in the enclosure.
Does not come with a charger.
You forgot to mention where you are located and if you will do shipping ;)
Otherwise, nicely filled out on the info (y)
SolarSolutions
Fixed it. Thanks!
This is a great opportunity to build your powerwall for cheap with long lasting quality batteries. Bulk prices available.
ynot
Can you quote shipping to BC Canada postal code V0H 1J0
And to Danville Wa, if the border opens up so we can take delivery in the US and hand carry home.
