elkooo
- Aug 9, 2019
- 32
Hello,
I now have a good collection of >3ah 18650ies to start with my 14s32p battery.
The closer I come to that, the more I started looking for inverters.
Recently I added more Solar Panels to our Roof (6 more --> ~2.5kWp). For those and the battery I would like to have a single phase inverter, which (ideally) can charge also the pack and which I can controll by an arduino.
So it should: :idea:
:exclamation: Do 230v single phase
:exclamation: Be able to handle ~3kWp of Solar Power (>300vDC)
:exclamation: Run from a 48V Battery System (and ideally act as a charge controller?!)
:exclamation: Be able be propperly limited / output-adjusted in battery operation (via RS323/485...)
The system shall cover our nightly loads off of battery power up to a max. that the battery is able to provide (which will be ~20A for starters --> ~1kWp). I plan to add another 32cells (maybe more) in parallel to the first 14 packs successively (BMS will be able to balance / handle well over 14s100p).
Any suggestions are welcome!! :heart:
Best,
elkooo
Best,
elkooo
