Hello everyone, I recovered a 36v 12.8A battery from electrical waste, i.e. 3200mah cells. https://octopart.com/fr/datasheet/inr18650-mh1-lg+chem-118692561.
3200mah = 2x more 1600mah.
For my bike, I'd like to add amps. At least 10 more amps, to get 36V ~22-25 amps. I currently have recovered cells:
Basically 2500mAh
2200mAh
2000mAh
with your packbuilder, I tried: with used ~2500mah cell
Total Capacity 14439 mAh
Divergence (from the average pack capacity) -133 mAh
Deviation (between the capacity of cells in the pack) 53 mAh
So my question, is on Battery ampere limit.
My battery make 12800mah.
and here i should upgrade in parallel to 14439mah so difference between 1539mah.
This 1539mah more ampere in battery, are don't this ampere too large capacity in connect parallel?
Basically 2500mAh
2200mAh
2000mAh
