Hi all,
I just picked up 32 Headway 38120 cells and I'm looking for project ideas.
I've always wanted to build a powerwall that eliminates peak and mid-peak rates and only recharges during off-peak hours. My house only has a 60A service using 1600kWh a month.
My truck has several amps and subs that devour lead acid batteries. I have a big cap that helps ... but it also self discharges over time ... so the truck needs to run every few days to keep the battery healthy.
I built an electric atv that is underwhelming. 800W DCmotor @30A powered by 4x36Vhoverboard packs is just not enough to have real fun. Perhaps a 1/3HP AC motor on an inverter would spice things up?
Apparently, these cells are many times more powerful than the familiar 18650s. One of the main reasons I bought these is their voltage allows friendly use in12V and 24V systems.
I'd love to hear the communities thoughts on these cells and what these are capable of.
Here are the specs:
chemical composition
360
Here are the specs:
LiFePO4
Nominal Capacity
8Ah
Charging voltage
3.65V
Nominal Voltage
3.2V
Cut-off Discharge Voltage
2.0V
Charging Method
CC/CV
Maximum Discharge Current(continuable)
200A
Maximum Charge Current(continuable)
80A
Cycle Life
1500cycles 1C 100%DOD
2000cycles 1C 80%DOD
Work temperature
Charge -10?to 45?
Discharge -20?to 65?
Energy Density
83 Wh/Kg
Initial Internal Impedance
<4m?
Dimension(mm)
Diameter
38mm
Length
120mm(152 with screw)
Weight(g)
360
