48V pack for BBSHD (1000W motor) using 18650 2550mah Cells Molicel
andr333y
Hi, I am planning on building the pack for BBSHD mid drive motor for my ebike conversion.
pack would be 48V 13S 7P
Those batteries rated at 4A <= 60C and 5A<=45C
I understand the pack should be able to deliver 30a, because that's what the motor is rated for.
Would those batteries be enough?
Is this max rating? - could you post a spec?
Could you post the wattage of your motor(s)?
I don't say this to be discouraging, just sharing discussion...
In my experience, cells with a 4a max rating / 600ma standard rating (laptop cells) don't do well over 1a. At 1a, 7p would be 7a * 48v = 336w. If you pull a 700w surge (2a/cell) you may see the 4.15v/cell charge drop to 3.7v/cell (or something like that) instantly on power surge - and then drain down to 3.4v/cell rapidly. In other words, it might work to a degree but you may not be happy with limited range.
This is why folks use 10a or 15a max discharge cells for this type of thing - the voltage doesn't pull down so dramatically / shorten the usefulness of the battery. For example - https://www.batteryclearinghouse.com/products/30-cells-high-grade-lg-mh1-10a-3ah-cells-in-10s3p-pack - notice 10a continuous discharge.
If you could make the batter larger as in 14p or 21p it would help a lot using low-amp cells.
I would use escooter/ebike cells such as these https://www.batteryclearinghouse.co...asonic-ncr18650bd-10a-3ah-cells-in-10s3p-pack https://www.batteryclearinghouse.co...high-grade-lg-mh1-10a-3ah-cells-in-10s3p-pack https://www.batteryclearinghouse.co...2600mah-10a-lithium-ion-cells-in-rubber-packs or these in a prebuilt 13 s pack https://batteryhookup.com/products/2-pack-panasonic-48v-power-module-13s-6-4a-299-99wh from what i have read the 13s 48v packs have fewer controller failures than the 14s 52v packs. If you are not in the USA or Canada these would not be a good deal
DiggsUt
The BBHSD will pull over 1600 watts at peak through its stock controller.
Anything past 6-7p (@13 or 14s) on an ebike becomes rather unwieldy. Although I run 9p it is split between two packs. One on the downtube and one on the rear rack but I am a country cruiser. The guys on dirt like to keep it much lighter.
