Planning on upgrading/replacing some relatively old/tired batteries in my RC Baitboat i use for carp fishing/baiting up.
My boat has twin props, each powered by 2 x 7.4v li-ions, 1 x 12v lead acid for a Raymarine Sonar, 1 x 12v lead acid for
a wifi range extender, and 1 x 6v lead acid for a underwater camera winch system. Need to replace all the lead acids, which would reduce total weight drastically. Got acouple of hundred harvested 18650s that i can use, for something atleast. Will be buying new LifePos if necessary, if all else fails.
I understand the issue with 18650s and 12v setups, BUT, as i have loads of 18650s, wouldnt it be possible to overgun
a 4s buck down, for the 12v pack for the Sonar unit, which has the following power specs :-
Nominal Supply Voltage : 12vdc
Operating Voltage Range : 10.8v - 15.6v
Power Consumption at full brightness : 2.7w RMS
What about a 4s(6-10)p + buck down to 13v, balance charged to 4.0v max/3.0v min(16v/12v) ? Dont really need to
utilise the full capacity of the pack/each cell, so can overgun total capacity to compensate. I totally understand that LifePos ARE the easiest/most reliable solution, but we are talking about afew watts here, for the Sonar, and 5w max for the Wifi range extender amplifier unit.No powerwall specs required
