SaskBattery
- Apr 28, 2022
- 1
Jag35.com had a auction in Canada so I have a pellet (60x) of reclaimed scooter battery packs untested. I won too many lots so want to sell some.
Reclaimed R5-Shorty eBike/eScooter Battery Packs 470Wh 36v 13Ah. These compact packs contain the powerful and popular high-capacity lithium-ion LG MH1 3200mAh 18650 cells. These are very similar to the same packs as the very popular R5, JUMP packs and 40-cell scooter packs but without the need for an activating dongle. These can be used as 470Wh eBike battery packs, though originally made as E-Scooter battery packs. Connect x2 in parallel to make 36v 26Ah 936Wh. Connect x2 in series to make 72v 13Ah 936Wh.
Packs come with custom Julet output connectors (2-pin power male + 3-pin data female), and the input connectors are 2-pin female (Mini Molex/Tamiya?). If you want XT connectors you'll need to add your own. Packs may have some cosmetic blemishes from storage.
Let me know if you have any questions.
- I'm located in Saskatoon Canada.
- Can ship anywhere in Canada
- Jag32.com’s YouTube video explaining the packs
- Each pack contains 40x - LG MH1 3200mAh 18650 cells
- Selling for $70 CAD/Per Battery (Jag35.com is selling for $100 CAD/per battery (75USD) and will not ship to Canada) Same batteries bought from his auction in Canada.
- The battery packs are the same as Jag35.com sells see: https://jag35.com/collections/lithium-batteries/products/r5-shorty-36v-13ah-470wh-ebike-scooter-battery
- Will ship anywhere in Canada
Specs
- Capacity: 12.8Ah
- Size: 13" L x 4" W x 2.75" H
- Continuous Discharge: 23A
Charging
Charger sold separately. These packs can be charged using a standard 42v 2A charger. Make sure you choose a charger with the right connector, if not you'll have to splice in your own connector. Recommend fully charging this pack as soon as you receive it.Range
- Can give you a range of approximately 30-45 miles at low speeds (10mph), or approximately 15-20 miles at high speeds (20mph).
