jesse.rizzo
- Sep 13, 2017
- 16
Hello all,
Just beginning my DIY powerwall journey and I've got a few unrelated questions.
I've seen in a few places that li-ion batteries have 99% charge efficiency. So if I put in 2000mAh into a battery, safe to say if has pretty close to 2000mAh capacity. Right? Any reason it's better to test capacity during discharge than charging?
You're supposed to cut of charge when the charge current drops to 3% of the capacity. Is that 3% of the original capacity, or the actual capacity. Ie if a 2000mAh battery only has 1000mAh of capacity left, do we cut off charge at 60 or 30 mA?
Is a BMS necessary if I'm willing to babysit my batteries. It will only be for emergencies, so I'll probably only need it for a day. Then I can disconnect everything and just charge in parallel. If I do this can I go without a BMS?
Thanks for any help.
