Riplash
- May 27, 2018
- 72
Hello All,
There has been a lot of discussions recently about passive balancing versus active balancing with a B.M.S. But I haven't seen any discussion about balancing a pack by charging only the lower cells. Do any of the B.M.S.'s or charging systemsthat are used for Powerwall's do active or smart charging?
For instance if I had a 14S battery and all the cells except number 5 were at 4.10 volts, and cell number 5 was at 3.90 Volts. I would attach a localized charger to charge cell bank number 5 to 4.10 V and not charge the rest of the cells. If I design a BMS and Charge Controller, I would have it measure all the voltages of the cells, and if a cell is so far lower than the average voltage of the cells in the rest of the pack, I would have the bms/charger just charge the lowest cell till it is brought up to the average cell voltage.
Do you know if any of the systems that are used for Powerwalls do this? Or what some of the advantages or disadvantages of doing thiswould be?
Thanks,
Ryan
Thanks,
Ryan
