Stefanseiner
- Apr 16, 2020
- 79
Hello everyone,
according to this thread -> Cheap Chinese Active Balancers
I think it disqualifies these balancers because the balancing-start-voltage is too high and you can't change the parameters.
But: has someone tested this chinese active balancer with bluetooth app?
-> Aliexpress
There are variants with 1A, 2A, 5A or 10A balancing current, and it comes with bluetooth and some values are adjustable via app.
But the description is very poor and I can't see which parameters can be changed in which range.
I installed the app just for testing but without having the balancer connected you only can change the language (between chinese and englisch).
So does anybody knows this balancer and can tell something about it?
daromer said:Yeah you unlock some capacity but only IF your pack nominal current draw is lower than the balancer can balance. And for most users thats less energy gained than the cost over 10 years IF you look towards that cycling Them that Hard so you need to bottom balance you wear out the cells within a year anyways![]()
-> Aliexpress
