Have a 10s (5 leaf modules) and a 10s 2p (10 leaf modules) batteries that I want to run between 38 and 40 volts. Have set my charge controller and/or power supply at 41 volts and they are taking a long time to bring the battery packs up to 40 V, in fact I usually wind up using them before they get to 40 V, would if be advisable to increase the voltage output? The 10s 2p has a BMS so that should cut out if the charger is set high enough. Just recieved a boost converter which I plan on connecting to the 10s 2p bank so I can connect up to the 32 V solar panel that makes a sun/rain/snow shade for the tractor.
Trying to learn here, thanks in advance for any input.
Tony
Tony
