- Oct 8, 2016
- 5,665
ATS or Automatic transfer switch is something you can use to switch between grid an inverter or generator. In most solar systems that have booth inverter and charger like off-grid and hybrid systems already have an ATS built in. But if you want to build your own or just understand some parts of it I have so far 4 videos in this area.
There are a coupld of things to understand when doing this kind of load transfer. Like the fact that it takes 10ms. That you need proper contactors where both sources NEVER can be engaged at same time. The fact that if you dont synchronize the frequency you will get huge voltage spikes.
More info can also be found here:http://diytechandrepairs.nu/automatic-transfer-switch-diagrams-how-to/
