Well, would you look at at that! My critical event was on and I have a log.
I don't see the issue, do you?
System - SYS
WatchMon
TimeStamp 3/21/2021 11:55:06 PM
System status information
Device Time Startup Ambient Supply
3/22/2021 5:55:17 PM 3/20/2021 7:08:10 AM -40ºC 45.31v
Versions Hardware Firmware Software SerialNo
5.3 5.5 2.0.14
OpStatus AuthMode CMU Mode
Empty Default Normal
SysFaults: WizardSetupRequired,
Live status information
Min @ ID Max @ ID Avg Repeat
CellVolt 3.07v @ 6 3.43v @ 12 3.29v 302
CellTemp 22ºC@ 10 25ºC@ 6 23ºC
BypassAmp 0.00A @ 0 0.00A @ 0
BypassTemp 14ºC@ 1 15ºC@ 15
BypSession 0.0mAh@ 0 628.0mAh@ 19
Total Overdue +Final +Initial InBypass
NumOfCells 28 0 0 0 0
SoC% Temp Volt Amp
Shunt -1.5% 36ºC 46.02v -0.174A
ToEmpty ToFull
Nom Capacity -1.666 101.666
Est Duration 45.5d 45.5d
Recent Consume 10.533 0.000
Expansion board
Input Run/Idle = off
Input Charge/Normal = off
Critical logic
control BattOK state
status LowAmbient, LowIdleShuntVolt,
Charging logic
control LIMP state
Idle Bypass: off
status LowAmbient, LimitedShuntVolt,
Discharging logic
control OFF state
status LowCellVolt, LowAmbient, LowShuntVolt, PauseShuntVolt, LowShuntSoC, PauseShuntSoC,
Thermal Heating Logic
control OFF state
status LowAmbient,
Thermal Cooling Logic
control OFF state
status LowAmbient,
Remote Logic
ActV ActA TgtV TgtA state
Charge 0.0v 0.0A 58.1v 0.8A LIMP state
Dischg 0.0v 0.0A 0.0v 0.0A OFF state
Daily Session information
Min Max
CellVolt 3.04 4.31
Thermal 9 27
ShuntSoc -1.5 101.5
ShuntVolt 45.73 57.34
SupplyVolt 44.89 56.65
Critical Events 0
Charge Dischg
ShuntPeak 29.02 47.68
Cumulative 67.575 125.757
Banding(hr) A B C D E F G H
SoC% 3.4 1.8 2.7 2.6 5.9 0.7 0.2 0.6
Thermal 0.0 0.0 0.0 0.0 12.7 5.2 0.0 0.0
Cell Node information
ID Bypass Initial Session Amp MinV MaxV MaxT BypT HiT HiBypT LoV HiV BypV BypA DatEr Reset CalV RepCV Serial HwVers
1 3/21/2021 5:35:40 PM 50.3 mAh 0.00A 3.35v 3.35v 23°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW5.3 FW5.5
2 3/22/2021 6:39:02 AM 0.2 mAh 0.00A 3.20v 3.20v 23°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 90 HW5.3 FW5.5
3 3/21/2021 5:35:54 PM 35.5 mAh 0.00A 3.40v 3.40v 23°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW5.3 FW5.5
4 3/21/2021 5:34:06 PM 99.9 mAh 0.00A 3.24v 3.24v 23°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 142 HW5.3 FW5.5
5 3/22/2021 6:32:31 AM 38.3 mAh 0.00A 3.13v 3.13v 23°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW5.3 FW5.5
6 3/22/2021 6:32:49 AM 13.9 mAh 0.00A 3.07v 3.07v 25°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 18 HW5.3 FW5.5
7 3/21/2021 5:37:20 PM 1.4 mAh 0.00A 3.40v 3.40v 25°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW5.3 FW5.5
8 3/22/2021 6:23:35 AM 71.5 mAh 0.00A 3.20v 3.20v 25°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 75 HW5.3 FW5.5
9 3/22/2021 6:34:40 AM 15.4 mAh 0.00A 3.34v 3.34v 25°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW5.3 FW5.5
10 3/22/2021 6:34:10 AM 28.3 mAh 0.00A 3.36v 3.36v 22°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 74 HW5.3 FW5.5
11 3/22/2021 6:34:13 AM 1.6 mAh 0.00A 3.41v 3.41v 22°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW5.3 FW5.5
12 3/22/2021 6:35:09 AM 1.4 mAh 0.00A 3.43v 3.43v 22°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW5.3 FW5.5
13 3/22/2021 6:26:35 AM 65.4 mAh 0.00A 3.24v 3.24v 22°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 55 HW5.3 FW5.5
14 3/22/2021 6:19:39 AM 187.6 mAh 0.00A 3.32v 3.32v 22°C 14°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 92 HW5.3 FW5.5
15 379.8 mAh 0.00A 3.33v 3.33v 25°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW8.0 FW8.0
16 321.6 mAh 0.00A 3.33v 3.33v 25°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW8.0 FW8.0
17 328.6 mAh 0.00A 3.31v 3.31v 25°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW8.0 FW8.0
18 352.7 mAh 0.00A 3.28v 3.28v 25°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW8.0 FW8.0
19 628.0 mAh 0.00A 3.32v 3.32v 25°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW8.0 FW8.0
20 106.8 mAh 0.00A 3.37v 3.37v 24°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW8.0 FW8.0
21 355.0 mAh 0.00A 3.36v 3.36v 24°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW8.0 FW8.0
22 158.6 mAh 0.00A 3.34v 3.34v 24°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 4 HW8.0 FW8.0
23 165.6 mAh 0.00A 3.41v 3.39v 24°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW8.0 FW8.0
24 417.9 mAh 0.00A 3.27v 3.27v 23°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW8.0 FW8.0
25 391.1 mAh 0.00A 3.18v 3.18v 23°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 4 HW8.0 FW8.0
26 363.4 mAh 0.00A 3.21v 3.21v 23°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 0 HW8.0 FW8.0
27 172.3 mAh 0.00A 3.21v 3.21v 23°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 4 HW8.0 FW8.0
28 103.0 mAh 0.00A 3.17v 3.17v 23°C 15°C 35°C 75°C 2.90v 4.20v 4.11v 0.61A 0 0 0 250 HW8.0 FW8.0
