sofaking5522
- Dec 25, 2020
- 32
Hello,
New to the batrium watchmon 4 with expansion board.
I tried searching the batrium and this site to see how to configure the charge and discharge relay. What I came up with from reading the online documentation is to use the discharge and charge on for the discharge relay and charge relay respectively. The problem I'm having is that the charging control logic is always showing off state even though everything is within the tolerances (all of the states are ticked blue except for the bypass session; this one is not set).
How do I get the charging to start working? how can I get the bypass session to set? Am I doing this right or is there another way to control and charge/discharge relay
thank you
thank you
