slimf
- Sep 26, 2017
- 226
Hi
Today my batrium keeps tripping my breaker - and I am trying to work out why. This is the log I extracted. It shows 3 critical faults, but I am attempting to determine exactly what the fault is!
Does someone know how to read this log? I cant work it out.
Note: I noticed Ambient Temp is -40 (and I can assure you its not) - However I don't have any low ambient settings enabled - So regardless it shouldn't cause a critical fault. Can someone advise if this is normal on a WM5? Ive never noticed it before, but then again never really took any notice of it.
System 4795 - SYS4795
Tower of Power
TimeStamp 14/11/2021 3:06:31 PM
System status information
Device Time Startup Ambient Supply
14/11/2021 3:06:38 PM 14/11/2021 1:35:37 PM -40ºC 56.73v
Versions Hardware Firmware Software SerialNo
5.3 5.9.47 2.17.9 308317320
OpStatus AuthMode CMU Mode
Idle Default Normal
SysFaults: Nil
Live status information
Min @ ID Max @ ID Avg Repeat
CellVolt 4.10v @ 1 4.10v @ 2 4.10v 6700
CellTemp 21ºC@ 1 23ºC@ 6 21ºC
BypassAmp 0.00A @ 0 0.00A @ 0
BypassTemp 25ºC@ 1 25ºC@ 1
BypSession 59.1mAh@ 3 199.8mAh@ 8
Total Overdue +Final +Initial InBypass
NumOfCells 14 0 0 0 0
SoC% Temp Volt Amp
Shunt 99.5% 42ºC 57.48v 0.007A
ToEmpty ToFull
Nom Capacity 799.757 0.243
Est Duration 40.9d 8.0d
Recent Consume 0.106 0.000
Expansion board
Input Run/Idle = off
Input Charge/Normal = off
Critical logic
control BattOK state
status LowAmbient,
Charging logic
control ON state
Idle Bypass: off
status BypassSessionLo, LowAmbient, PauseShuntSoC,
Discharging logic
control ON state
status LowAmbient,
Thermal Heating Logic
control OFF state
status LowAmbient,
Thermal Cooling Logic
control OFF state
status LowAmbient,
Remote Logic
ActV ActA TgtV TgtA state
Charge 0.0v 0.0A 57.5v 160.0A ON state
Dischg 0.0v 0.0A 47.6v 100.0A ON state
Daily Session information
Min Max
CellVolt 3.97 4.13
Thermal 20 23
ShuntSoc 70.0 100.5
ShuntVolt 51.69 57.60
SupplyVolt 46.96 57.37
Critical Events 3
Charge Dischg
ShuntPeak 124.58 66.79
Cumulative 227.756 91.476
Banding(hr) A B C D E F G H
SoC% 2.6 1.1 5.4 6.1 0.0 0.0 0.0 0.0
Thermal 0.0 0.0 0.0 0.0 15.1 0.0 0.0 0.1
Cell Node information
ID Bypass Initial Session Amp MinV MaxV MaxT BypT HiT HiBypT LoV HiV BypV BypA DatEr Reset CalV RepCV Serial HwVers
1 14/11/2021 1:38:38 PM 72.9 mAh 0.00A 4.10v 4.10v 21°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
2 14/11/2021 1:40:21 PM 74.9 mAh 0.00A 4.10v 4.10v 21°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
3 14/11/2021 1:40:20 PM 59.1 mAh 0.00A 4.10v 4.10v 21°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
4 14/11/2021 1:40:19 PM 66.8 mAh 0.00A 4.10v 4.10v 21°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
5 14/11/2021 1:40:21 PM 66.8 mAh 0.00A 4.10v 4.10v 21°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
6 14/11/2021 1:40:25 PM 61.4 mAh 0.00A 4.10v 4.10v 23°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
7 14/11/2021 1:38:36 PM 96.0 mAh 0.00A 4.10v 4.10v 23°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
8 14/11/2021 1:40:20 PM 199.8 mAh 0.00A 4.10v 4.10v 23°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
9 14/11/2021 1:40:03 PM 129.5 mAh 0.00A 4.10v 4.10v 23°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
10 14/11/2021 1:40:24 PM 70.6 mAh 0.00A 4.10v 4.10v 22°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
11 14/11/2021 1:40:21 PM 95.8 mAh 0.00A 4.10v 4.10v 22°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
12 14/11/2021 1:40:22 PM 134.4 mAh 0.00A 4.10v 4.10v 22°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
13 14/11/2021 1:40:19 PM 116.1 mAh 0.00A 4.10v 4.10v 22°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
14 14/11/2021 1:40:25 PM 87.9 mAh 0.00A 4.10v 4.10v 22°C 25°C 55°C 75°C 2.90v 4.20v 4.10v 0.60A 0 0 0 250 308317320 HW5.3 FW5.9
Tower of Power
Idle Default Normal
SysFaults: Nil
SoC% Temp Volt Amp
ToEmpty ToFull
Expansion board
Critical logic
status LowAmbient,
Charging logic
control ON state
Idle Bypass: off
Discharging logic
control ON state
status LowAmbient,
control OFF state
status LowAmbient,
control OFF state
status LowAmbient,
Remote Logic
Min Max
CellVolt 3.97 4.13
Thermal 20 23
ShuntSoc 70.0 100.5
Critical Events 3
Charge Dischg
