Perhaps this?Hi,
I’ve have few problems recently, the main one is my batrium says “cannot save as it’s in read mode” I cannot change and save any changes I do and I need to do some changes, can anyone help?
Thank very much,
Phil.
You need to have the Batrium hooked to a PC with a usb cable. If Batrium does not see a physical connection you cannot go into Technician mode.batrium says “cannot save as it’s in read mode”
OK then explain to me if I unplug the watchmon USB cable from a powersource whether laptop or a 5V USB battery bank, I cannot enter technician mode and change setting?No you dont need wired connection to do changes. I have not done that for last 2 years![]()
4 batriums. ShowoffThis is important since i have 4 batriums running myself![]()
Hmm I will look at this first thing tomorrow and let you know if it sorted it, thank youThere is an "Allow TechAuth" option and I have mine On - maybe that affects things?
Yes, the screenshot (above) is from my WM4.Also I have the watchmon 4 will i have this option?
