Batrium Longmon Connectors
Dr. Dickie
Does anyone know the connectors that Batrium uses for the Longmon connectors. The positive and negative leads are not long enough for my packs, so I plan to hook them up similar to the way AveRage Joe did (solder them to the buss bars on the pack); however I would like to be able to connect and disconnect (in case I need to swap out a pack), so I would like to put a connector in-line. And so I would like to use the same type of connectors that they use--and not being sophisticated in connector I know the ones they use are common, but don't know exactly what they are called.
These work for me. They are JST ZH 1.5MM? I hope the label give you enough to locate something :)
Dr. Dickie
Fantastic, thanks OffGridInTheCity.
WOW, I never would have guessed that it would have such a hard time. Seems like no one sells these without wires attached.
