CarelHassink
- Oct 21, 2017
- 179
Hello All,
At the moment running a 72Kwh 56.25nomV 1280Ah ESS with a REC BMS, see my introduction earlier this weekend
REC uses a pre-charge unit, in my case operated at 12V, with a 4 seconds delay pre-charge of the capacitors in the Sunny Islandinverter.
In this set-up I use 400A Gigavac contactors (@48V-ish)
I wonder if I could stick with my current layout, using the Gigavac's + REC pre-charge unit, on a Batrium bms,
if I was to change to Batrium.
To do this I would need a NO contact, managed by the Batrium.
And I think this is the case.
But could someone confirm this??
See little youtube film with a demonstration set-up.
regards
CarelHassink
regards
CarelHassink
