Batrium problem.
Hank
Hi all,
I have got my Batrium BMS running for nearly two years. Today I have switched off whole system, I have disconnected power from WM5 and WM8 and I have replaced battery no 5, after I have noticed that one of the batteries is not recognised, please see attached picture, I have checked all fuses, I have rebooted both WM's, I have checked if the battery is OK with batrium testing tool. Anyone able to help me please?
Regards,
Hank
Pelle sweden
hi
try device sync, good luck
hi
Agree with @Pellesweden - check longmons/network wires. You can unplug, re-plug in the network connector on individual longmons... the longmon should show led on when you power it - showing it's functioning at a base level.
Do network tests and then sync.
Hank
Hi all, unfortunately this is centralised system without longmons and sync failed. I have contacted batrium, it looks like it's hardware failure, as they are not doing WM5 anymore, have ordered WM-CORE and CELLMATE, after I will have my system fully working, I will try to remove epoxy resin from WM5 and repair faulty device.
Regares,
DG98
[Batrium] are not doing WM5 anymore...
I discovered this when I attempted to buy an MM8 unit to expand my battery -- which was the whole reason I had originally purchased the WM5. Barely more than a year later, Batrium basically tells me they don't support any of that anymore.
I refuse to reward them by "upgrading" to the new equipment -- I am more inclined to find an alternative, even if it's more work, because I expect better than this from a company that sells cheap components at high prices and never delivers on promises like a monitoring app...
Cheers, John
Cheers, John
I'm with you. One of the reasons I still like Batrium is that I've been able to expand via longmons (that are compatible with my WM4) for 3 years now and was hoping this will continue. If they stop delivering it diminishes their brand.
Perhaps you can post your viewpoint on their Twitter account: https://twitter.com/BatriumTech
Emails are one thing, only 2 individuals usually see them. But at least with Twitter, there's a chance for a grander audience to view their thoughts and opinions on the matter.
I don't use Batrium personally, but considering that the *-mons use 2 wires to communicate, there shouldn't be an issue with backward compatibility. I can understand not upgrading the *-mons' firmware after a period of time, but they should still be able to be controlled by the Watchmon.
