Batrium Same Cellvolt Bypass
Headrc
I have looked all over the Batrium web site and looked all over Youtube etc. I cannot find a description of what the Same Cellvolt Bypass function does on the Cellmon Bypass Extra Mode. Does anyone here know? Thanks, Richard
Headrc
Thanks Mike ...still wishing there was an organized manual for Batrium.
mike said:
https://support.batrium.com/article/62-how-to-setup-autolevel-bypass-configuration-watchmon
Batrium said:
Same Cell Volt - trigger bypass on any high cell voltage to match low.
I've used Auto Level a few times when adding new packs, but looking at this - the sub-panel forSame CellVolt is the same as Auto Level - i.e, they areidentical. So that begs the question : what kicks off Same CellVolt. The Auto Level is kicked off based on "Bypass Volt" CV9 on the main CellMon screen. What causesSame CellVolt to engage?
Headrc
Hi Offgrid .....
Thanks for coming on board on this discussion ...I am wondering the same thing.
mike said:
Auto Level just has additional criteria that you can set on that screen.
The Auto Level Screen looks like this:
The Same CellVolt Screen looks like this:
I don't see any difference. Maybe I'm missing something?
LithiumSolar
That does look odd, but am guessing the setting are ignored for Same CellVolt based on what's said in the documentation. That would be a good question to ask Batrium to be sure I guess.
Auto Level - trigger bypass on any high cell voltage to match when the criteria allows this process to run.
Headrc
If someone does get an answer from Batrium please post it here!
Batrium
Dont use Same Cellvolt Bypass function, it is a obsolete functionprior to AutoLevel.The optionAutoLevelisavailable for general public use for chemistry other than LiFePO4.Same CellVoltremains available fora specificcustomer project that is not for general use, hence why itsnot documented.
