Linux or windows?Cell-King said:It turns out there was one other ui_chart in one of the flows but I removed it and the bar chart still doesn't show! I've tried a lot of things but no luck!
Cell-KingCell-King said:Hi Wolf, Sorry, I'm only seeing this post now! I wasn't able to graph the bar but I made another dashboard instead which sort of shows the same info. Not as pretty, but it works!
If anyone was able to fix the
"TypeError: TextDecoder is not a constructor"
please let me know as I still seem to have that project and google doesn't seem to have any further info. I thought I fixed it by adding the Binary Parser but it seems not!
Cell-KingCell-King said:................................ One night the low voltage state was reached and the Batrium tripped the breaker, but the dashboard still said the shunt state was "Idle". I would like to report on that too so I'll do some playing around with that setting when I can.
System 8093 - Wolf's
Wolf's PowIRwall
TimeStamp 6/22/2020 11:55:04 PM
System status information
Device Time Startup Ambient Supply
6/22/2020 11:55:22 PM 5/31/2020 4:39:19 PM 30C 53.02v
Versions Hardware Firmware Software SerialNo
4.3 4.10 2.0.12 324644513
OpStatus AuthMode CMU Mode
Discharging Default Normal
SysFaults: Nil
Live status information
Min @ ID Max @ ID Avg Repeat
CellVolt 3.71v @ 14 3.75v @ 4 3.73v 6700
CellTemp 23C@ 13 24C@ 1 23C
BypassAmp 0.00A @ 0 0.00A @ 0
BypassTemp 22C@ 14 24C@ 2
BypSession 0.0mAh@ 0 0.4mAh@ 4
Total Overdue +Final +Initial InBypass
NumOfCells 14 0 0 0 0
SoC% Temp Volt Amp
Shunt 40.5% 43C 52.39v -10.26A
ToEmpty ToFull
Nom Capacity 57.361 82.639
Est Duration 05:43 45.5d
Recent Consume 10.028 0.000
Expansion board
Input Run/Idle = off
Input Charge/Normal = off
Critical logic
control BattOK state
status OK
Charging logic
control ON state
Idle Bypass: off
status OK
Discharging logic
control ON state
status OK
Thermal Heating Logic
control OFF state
status OK
Thermal Cooling Logic
control OFF state
status OK
Remote Logic
ActV ActA TgtV TgtA state
Charge 0.00v 0.00A 58.10v 148.00A ON state
Dischg 0.00v 0.00A 47.60v 222.00A ON state
Daily Session information
Min Max
CellVolt 3.44 4.06
Thermal 19 29
ShuntSoc 1.0 101.5
ShuntVolt 48.76 57.02
SupplyVolt 49.24 57.48
Critical Events 0
Charge Dischg
ShuntPeak 38.15 30.50
Cumulative 151.460 136.578
Banding(hr) A B C D E F G H
SoC% 4.0 1.6 1.3 2.4 3.0 2.3 2.1 7.2
Thermal 0.0 0.0 0.0 0.0 23.9 0.0 0.0 0.0
Cell Node information
ID Bypass Initial Session Amp MinV MaxV MaxT BypT HiT HiBypT LoV HiV BypV BypA DatEr Reset CalV RepCV Serial HwVers
1 6/19/2020 4:49:31 PM 0.1 mAh 0.00A 3.72v 3.72v 24C 23C 55C 65C 3.00v 4.15v 4.08v 0.84A 16 2 0 250 316184432 HW6.2 FW2.2 BL2.0
2 6/22/2020 1:44:26 PM 0.0 mAh 0.00A 3.72v 3.72v 24C 24C 55C 65C 3.00v 4.15v 4.08v 0.84A 0 3 1 250 316176447 HW6.2 FW2.2 BL2.0
3 6/22/2020 5:05:26 PM 0.1 mAh 0.00A 3.73v 3.73v 24C 24C 55C 65C 3.00v 4.15v 4.08v 0.84A 10 4 1 250 316111230 HW6.2 FW2.2 BL2.0
4 6/22/2020 5:30:37 PM 0.4 mAh 0.00A 3.74v 3.75v 24C 24C 55C 65C 3.00v 4.15v 4.08v 0.84A 3 5 0 250 316100340 HW6.2 FW2.2 BL2.0
5 6/22/2020 5:20:39 PM 0.1 mAh 0.00A 3.72v 3.73v 24C 24C 55C 65C 3.00v 4.15v 4.08v 0.84A 0 6 130 250 316114799 HW6.2 FW2.2 BL2.0
6 6/22/2020 1:31:40 PM 0.0 mAh 0.00A 3.73v 3.73v 24C 23C 55C 65C 3.00v 4.15v 4.08v 0.84A 0 7 0 250 316186980 HW6.2 FW2.2 BL2.0
7 6/19/2020 2:53:25 PM 17.0 mAh 0.00A 3.72v 3.73v 24C 23C 55C 65C 3.00v 4.15v 4.08v 0.84A 70 8 130 250 316102151 HW6.2 FW2.2 BL2.0
8 6/19/2020 12:25:50 PM 0.3 mAh 0.00A 3.73v 3.73v 24C 23C 55C 65C 3.00v 4.15v 4.08v 0.84A 1 9 129 250 316099104 HW6.2 FW2.2 BL2.0
9 6/22/2020 3:05:19 PM 0.3 mAh 0.00A 3.72v 3.72v 24C 23C 55C 65C 3.00v 4.15v 4.08v 0.84A 128 10 131 250 316114066 HW6.2 FW2.2 BL2.0
10 6/22/2020 3:44:34 PM 0.2 mAh 0.00A 3.73v 3.73v 24C 23C 55C 65C 3.00v 4.15v 4.08v 0.84A 8 11 0 250 316177575 HW6.2 FW2.2 BL2.0
11 6/21/2020 2:57:45 PM 0.1 mAh 0.00A 3.72v 3.73v 24C 23C 55C 65C 3.00v 4.15v 4.08v 0.84A 128 12 130 250 316187654 HW6.2 FW2.2 BL2.0
12 6/18/2020 12:48:09 PM 261.4 mAh 0.00A 3.73v 3.73v 24C 23C 55C 65C 3.00v 4.15v 4.08v 0.84A 0 13 7 250 316189745 HW6.2 FW2.2 BL2.0
13 6/22/2020 3:56:50 PM 0.1 mAh 0.00A 3.72v 3.73v 23C 23C 55C 65C 3.00v 4.15v 4.08v 0.84A 5 14 0 250 316114117 HW6.2 FW2.2 BL2.0
14 6/22/2020 5:26:19 PM 0.2 mAh 0.00A 3.71v 3.71v 23C 22C 55C 65C 3.00v 4.15v 4.08v 0.84A 128 15 3 250 316105276 HW6.2 FW2.2 BL2.0
That's a possibility but I was not doing a sync at 10PM at night. Unless the Batrium in its infinite wisdomdid it.Cell-King said:Interesting. If it happens when you are syncing the longmons (the "Device Sync" button), the page states that there is no monitoring during that step so maybe the UDP listener is seeing no value or NaN and sending that to Influx?
Congratulations on getting your watchman 4 data to influx and grafana.Solardad said:................going to start with bringing in my iotawatt sense data next into influxdb then into grafana
from there i am thinking about weather data / sensors. anyone bringing in this type of data for analysis?
my thought is to leverage for instance a 'solar irradiance' value to control a pool pump ex. high irradiance then increase the rpms.
has anyone looked into the difference of node-red vs maybe home assistant for that scenario?
True but how else are you going to learn node red.daromer said:Just use the built in open weather map palette and direct to influx output. No need to complicate it![]()
So what are you saying? Is there apalette to custom tune Openweather to my liking? I haven't found one. I also haven't found a custom palette for Watchmon 4. But thanks to all your initial hard work and Tim aka"Bloater" we have a working flow.daromer said:To many People install node red and starts to write functions. Actually, most functions exist as palettes IF done correctly.
