12ax7
- Sep 13, 2017
- 10
Hey everyone! I've been doing extensive research and watched pretty much every youtube video you guys have posted.
All great stuff!
I was considering building my own BMS system and came across Batrium.
Here is my question.
I'm going to be running a mixed chemistry environment using 18650 Li-Ion cellsthat I acquire over time in a 40p 14s string to net me 51.8v nominal.
As well I'm going to have another battery bank that will consist of 32650 LiFePo4 cells arranged in a 20p 16s string to net me 51.2v nominal.
The idea is I would just run the Li-Ion bank at 51.2v nominal as well to keep the banks someone in sync with each other feeding a Sigineer 12kw split phase inverter (US)
I can imagine if I don't line the overall capacity with each other I'll need to somehow diode these banks from each other so one doesn't back feed to other after some extensive load.
I suppose thatis for another topic.
But using Batrium can I individually specify the voltage of each cell? Or is it global?
I'd prefer not to have two individual Batrium systems.
Hopefully I'm making sense here, and look forward to me showcasing my project as I go. :blush:
Attached is my initial rough draft for a 14s Li-Ion battery
All great stuff!
