daromer
Moderator
- Oct 8, 2016
- 5,665
clamp meter is your answer.... Dont use that if you want to measure below 5A. Especially if you want higher accuracy.
As said before and i say it again. Negative and positive of a cell must always have the same current going/in/out if you say it like that. Its the law of phsysics. It cant be anything else because if it would be the laws around and how people build inverters, devices. yes everything around electronics are flawed.
Dont mix up current on pos/neg on one cell comparing to current going into different paralelled batteries. 2 totally different things and both relies perfectly on how u=i*r is setup. Please just draw it up on paper and calculate it and then go back and ask your self why your device doesnt show the same values. Then read up on how a clamp meter works.
And im still waiting on a drawing showing exactly how you held the device and where you meassured. Ie the current that is introduced in the circuit + voltage and then every point you meassured.
