- Sep 25, 2018
- 2,009
I'm starting this thread to start a discussion on how cells behave in parallel in a pack.
Before any of you poo poo this and say that all this has been studied and there are many papers out there on this I will concede and agree.
But of all the studies that I have read they all seem to use only the same cells from the same manufacturer whether Lipo, LiIon, LiFePO4and are not mixing cells of different capacity, manufacturers and IR. Neither are they mixing low drain and high drain cells.
https://www.sciencedirect.com/science/article/pii/S0378775316309995
https://www.sciencedirect.com/science/article/pii/S0378775316300015
https://www.sciencedirect.com/science/article/abs/pii/S0378775315306911
The studies all come to a very similar conclusion that as cells degrade the interaction among them causes the cells to be stressed.
I am here to help us understand this phenomenon with down to earth layman's analysis and hopefully a good discussion.
I am no mathematician and most of the formulas the studies use are a complete mystery to me but I do understand charts and experiments.
I have built a board with an ESP32 Dev module and hooked up 4 INA219 I2C Bi-directional DC Current Power Supply Sensors to it. All the INA219
chips are from the same lot so deviation should be minimal if any at all. Along with the cell holder and the ESP32 with the INA219s attached
there is a Buck CC/CV charger and a ZB206+ discharger on it.
The data is going to an influx database to record the4 parameters that the INA219 produces.
Buss Voltage
Load Voltage
Milliamps
Shunt Voltage
The cells will be charged to 4.2V until mA cutoff saturation and then discharged to whatever voltage we want to 3.0V to 2.8 or whatever some of you want to experiment with. IRand voltagewill be measured before the test and recorded.
We can experiment with a charge Voltage of 4.0V and a discharge to 3.2V etc. etc. etc. The range of parameters is unlimited.
You can participate in this study with suggestions of what cells to test in combination of each other.
All of this data is then graphically represented on a grafana dashboard for analysis.
I have added annotations and will continue to do so at the start of each cycle on the milliamp chart to indicate the cell part number IR and Voltage.
As this data accumulates you are more than welcome to look at it at any time http://wolftech.mynetgear.com:4562/...s?orgId=1&from=1565775270104&to=1565786145474 username guest password guestw
To view the data correctly choose a time frame
Once you learn how to use grafana you can drill down to the time frame you want to see and then can extrapolate your own conclusions. Anything prior to 8/11 is experimental and should be disregarded.
The first set of cells you see in this graph are
Discharge curve at 2 Amps for the pack and charge curve at 4 Amps for the pack
The second set are all UR18650FMs which are undergoing a 1A per pack discharge right now. Combined mAh of the 4 is 9615mAh so it will take at least 9 hrs do discharge at that rate. They have been discharging for almost 4hrs.
Questions, comments, rants, and raves bring them on.
Buss Voltage
Load Voltage
Milliamps
Shunt Voltage
