Best BMS setup for a 8S2P 360Ah 24v CALB battery .....
Mezbatt
Can I have recommendations for BMS on this setup bearing in mind my location and availability based in the UK...???
Roland W
Imo any 8s LFP BMS will do. I recommend the BMS max current be 2x your expected max current during normal operation. Due to the nature of LFP (resting behavior), BMS main task should be watching limits. Your charger to be set to a max voltage around 3,5v per cell and inverter cutout around 3v per cell. That will give you a operational range of 95% of capacity and will never even require balancing if you start with a equalized pack.
At least that's what my experience is with this type of prismatic, high capacity cells.
