So a discussion on blocking diodeswas underway in another thread but was off topic for that thread (no problems with mods keeping threads close to title, helps the site be logical, etc).
That thread is here: https://secondlifestorage.com/t-Calculating-Solar-System-DC-Wire-Size-and-System-Installation
I'm still interested in should we be using blocking diodes (different to bypass diodes) in systems where there are parallel strings on panels & one or more stringmay get shaded differently.
Is it a problem to have an example (but likely)situation where most of you array is putting out Vmp x number ofpanels in series. Then there's say one string that's shaded.
Is it detrimental for the shaded panels to have the full system voltage applied when they're not generating themselves (ie assuming no blocking diodes)?
On one hand, pretty much any light in the sky seems to bring panel voltage up, so shaded strings voltage might only be a bit less than the system voltage - so probably not an issue.
On the other hand, Australian Standards AS 5033 for solar panel installs, etc does mention including them in parallel string situations,as do links provided by Sean (from the other post)
https://www.electronics-tutorials.ws/diode/bypass-diodes.html
The problem of night time current bleed back through panels connected to batteries seems to be solved by have pretty much any charge controller between the panels & batteries.
The problem of forcing voltage onto a shaded panel is not so clear.
There's also the(less likely) situation of when there's a fault in a panel like a shorted bypass diode or shorted cells. Then the applied voltage from the rest of the system starts becoming more serious I think.
Thoughts?
Thoughts?
