To be able to control each string individually you can use a DC MCB (photo 3 "TOMZN MCB 125A DC" and photo 4 "DC Circuit Breakers All Sizes") with an amperage of 1.5x/2.0x your string amperage. If a string is for e.g. 10A then a 20A DC MCB will be ok (I bought 20A DC MCBs for my each of my three 8.64A strings). You choose a slightly over-dimensioned MCB to avoid it working at it's nominal limits. It's a good practice to disconnect panels from the inverter when doing maintenance.my question is which one should i but for pv strings as there are few types but not sure if it doesn't matter which one will get or need specific one so advice needed, attached pics of them no.4 or no.5? also attached pics of my inverter details, ac input breker and battery breaker so please advice
Oh wow, I was really struggling with this one! I found this other info which was about the relationship between Ampere and Power, which are not always proportional... but your answer is the correct one I thinkSince the wire has 200c rated silicone insulation it should do 60A uou can up size the wires connected to the b- p- wires
Maybe that one started off with less charge. Did they all have the same voltage initially?why one series got 2.7v and rest 3.4v?
Are you sure all the cells in the trouble module are properly connected? I don't know how your battery looks, but it's easy to miss a blown fuse or bad connection.all batteries were the same, brand new and had a nominal voltage
