I see it is well balanced.
I don't know if anyone has shared a smart daly bms settings here
This is for a genric smart bms
low voltagecut off per cell 3.45v battery pack 48.3
you can go lower but not much capacity below 3.4v
high voltage cut off is often set to per cell 3.9v-4.15v Battery pack voltage 54.6v- 58.1v
Can you set when the balance starts? I would start it at 3.8v but from the looks of things you don't need balancing very often at first. 4mv is not a much. usually there is a setting that triggers balancing such as >than 30mv
battery tempature high 60c* low 0c
** I would set this lower probably 50c
