- Jan 7, 2017
- 7,538
What is aBMS and what is good for?
A BMS, or Battery Management System, is an acronym of a device that in some degree or another actively do some work with your batteries or protect them. A BMS can consist of several parts but some can also be left out.
The attributes that are common in a BMS are (All described down below)
Its important to understand that not all BMS boards or system do consist of all 3 attributes and some of them only have parts of above.
The main function of a BMS is to protect the batteries from being damaged, and possibly causing a fire or explosion, resulting in property damage, or loss of life. Balancing is a way to ensure that you over longer period of time will stay in shape and not end up with the fault protection kicking in.
- Fault protection
- Balancing
- Monitoring
