BMS- Which methods to calculate the battery SOC is more accurate?
Jwilmesbrady
SEPLOS smart BMS gets the battery real capacity at its initial full charge of the battery through time plus charging current.
And will calibrate through voltage in the using process in case if the battery never fully charged.
And now they updated the firmware, to get the real capacity at a full discharge cycle.
And calibrate through voltage in the using process if the battery never fully discharged.
Basing SOC on voltage level is tricky and in many cases not even possible. First of all the battery must have been resting for atleast 5 minutes and you need to know the exact Voltage to SOC curve including aging.
The best way and to be honest the only "real" way is to calculate the energy going in/out and have a meter that also can take into account losses due to how hard you push in terms of C. (C factor as in often translated to Ampere)
Most systems dont have the callibratio based on C and only do colloumb and for most users thats fine.
Then you calculate the amount going in and out and you always know the SOC. You then reset this to either 0 or 100% based on reaching your top voltage level or bottom level and that becoms your ref point.
Hope its understandable.
Agree with @daromer. In my case - I've given up worrying about SoC to any specific degree. My focus is off-grid power production. So I worry about max charge settings (hi voltage) and Inverter off (low voltage) and overall health (balance/capacity/long-life) of the battery bank.
I do track many statistics, so I have a pretty good idea of battery bank capacity and a general idea of SoC - but accurate SoC at any given moment is fuzzy and I've found that it's not important for general operations day after day :)
To answer the question - I infer SoC by the voltage along the charge/discharge curve of the specific battery + a compensation factor for extreme amp levels (compared to routine) that significantly pull down or push up the current voltage.
Jwilmesbrady
Yes, they calculate the real capacity that going in/out from the shunt.
But the real case is, the battery may not get to 0 or 100% for months, without the calibration through voltage, the SOC would be deviation over time.
The detailed calibration as follows:
Adjust the SOC to 95%, when the overvoltage occurs, and the SOC is lower than 90%.
Adjust the SOC to 70%, when the voltage reaches 3.4v*series.
Adjusting to lower voltage than top voltage is quite useless on LiFePo4. 70% and 85% can be exact same voltage as example
You have to live with it drifting and or you have to charge it fully. Thats the life of using this type of system im afraid and the only way to reduce the drift is to get a high quality meeter for it
LiFePo4 should only have the voltage used above 3.5V or below 2.9V or around. Thats where you potentially know the SOC ;)
Jwilmesbrady
Test report of SOC-VOLTAGE at different temperatures.
