Another little note, im working (slowly) on a rs485 bridge/gateway.
The two systems growatt and victron fights a bit, and that means i can hear the victron working at night when the growatt is running low. (recharging the growatt system).
Right now i have two different consumption meters (both phase 3) right after each other, thereby essentially reporting the same number to the two inverters/chargers.
I would like to have one meter (that i would care to read), and then in controlled manor share information with chargers. Ie priority to one charger up to some amount or a period of surplus power. Thereby the chargers would fight, one could become my primary and the other secondary in a controller manor.
In the summertime this doesnt matter, since both batteries typcially are charged at around 11-12 mid day. It is only the discharge that seems to not work optimally.
Dont expect this to be completed in the next 6 months at least, it is a hobby item. If you know of some software that can do this on ie a rasberry pi or a arduino device, i will park my project and get it.
The main consists of two parts. Different RS485 (serial + tcp(modbus)), and different protocols/registers. And my idea is to make it sort of plugin able to add a new protocol. That would allow others to fairly easy add their meter / inverters protocol.
It would also allow you to buy another meter than the one the manufacturer recommended. (remember the issues with the EM24 that almost made me jump out the window... i live at ground floor, so risk i minimal
In regards to building your own device:
Research, fuses EVERY where, make sure cable with and fuse size makes sense. Also if possible place away from things you hold dear, i'm not sure insurance will love the concept of a homemade battery. I don't know much about the details about any other setup, but there are alot of youtbe videos about the battery construction and it seems the biggest problem, is figuring out min + max voltages that are well within safe range.
Finally i'm dreaming about a Nissan Leaf battery they seem to be running at around 30kwh which would cover more than one days consumption.
I would most likely build it of the same type of components, but even though Carel WARNED ME, im still intrigued by using the battery in a high voltage scenario, since the battery could remain closed, and potential use its own bms, maybe supported by SimpBMS, since it handles communication to the Victron.
I would also try and locate enough means to run multiple victrons to try and duck the noise issue. It also seems that the components become very expensive when the Amps rise above a certain point.
Funny detail... i still havent managed to figure out how much power is available to me in the i3 battery, it has a nominal value of around 17-20kwh i think, and im guessing im seeing somewhere in the 10-15 kwh range.
Another thing... for once im looking forward to my car going to the scrap heap, because im going to pinch the battery and have a looot of kwhs available to me then
Take care all, im sorry i dont frequent this site more often, but life keeps me pretty busy.
