There is however somethink you could use a spare pack for:
Active balancing. I have been think about it, and perfect (but slow) active balancing could be achieved using a spare "flying" pack and some relays (14S-pack would need 14*1+5 relays to be precise).
There are different algorithms for this, but I would use:
Step0: Log all cell-levels
Step1: Select Higest and Lowest.
Step2: Connect flying to higest for x minutes
Step3: Disconnect for x ms
Step4: Connect flying to lowest (from step1) for x minutes
Step5: Disconnect for x ms
REpeat, and keep doing this as long as system is operational. Under charge, under load, allways.
Has it been done before? yes. Its called flying capacitor balancing - but this uses solid-state and caps and can therefor not overcome a minimum voltagedrop through the FET-switches for balancing - I would use mechanical relays, with a specific loadconnecting relay (protected with freewheeling diodes), and the rest as normal. 12V auto-realys cost nothing and are good for millions of swithes under no load, and balancing would converge to 0.00V difference.
Try a google for "flying capacitor balancing"
Main advantage - active balancing "for Free" since we allready have some spare batteries
