Built battery pack for Kweld spot welder
zerberfert
Hello again,
I bought a Kweld spot welder and it came in last week, (I don't want to solder to my batteries). I bought some SPIM08HP's to power it. I built it in a 7s config and the Kweld would not calibrate. The error message was "overcurr". The battery pack was too much for the Kweld. I downsized the battery pack to 6s and it works just fine.
So anyone buying a Kweld spot welder and using SPIM08HP's don't go higher than a 6s configuration.
Just wanted everyone to know,
Zerb
Did you read the documentation on what battery is recommended?
The battery should be min 800A capable and not above 2000A.
Input voltage for welding: 4V - 30V, enabling the use of ultracapacitors
vegburner
I read on the esk8 forum that a couple of people tried using the SPIMs and could only get a 4s 800a setup before overcurrent. So are you getting past calibration with a 6s? How many amps?
I have the SPIMs too.... hate it that i didn't try.
I just ponied up and bought a Turnigy Graphene 3s 6AH green 75C which pushes 1500a (recommended in the literature).
Absolutely LOVE the kweld though and can't believe how smooth it is compared to the suunko.
thanks for the info.
zerberfert
I did:
Turnigy nano-tech 3S/5000mAh/130C Lithium Polymer battery (link). I have stress tested one of them for several complete discharge cycles, and it shows no visible swell thereafter. The measured current is 1300-1500 amperes.
Turnigy graphene 3S/6000mAh/65C Lithium Polymer battery (link). These do not show any swell after a few full power discharge cycles, but I have no data on their life span yet. The current level is comparable with the nano-tech model.
Ultracell UXL65-12 (link). According to feedback from a user, the current reported by kWeld is approx 1000A when tested with 0.15mm nickel strips.
Bosch SMT 31-100 (link). According to feedback from a user, the welding current reported by kWeld is approx 1400A.
The SPIM08HP's are 8000mAh/200C. It has a higher constant and burst charge than the above batteries. If I remember right, when I did a few test spot welds it showed that 1600A was used.
Seems to be good for the Kweld. Or am I misreading specs?
With 7s it was overcurrent, I dropped it to 6s and it works find. Calibrated first try. I will have to double check but I think it said 1600A was used.
Its not only about current but voltage.
6s is 2* the Power to 3s that is a standard recomendation. Dont forget that.
