Cable to extend Tesla bms loom
Ford pop racer
I have 7 Tesla model S modules that are not all in one pack and need to extend the cables. If grey is not used do I only need 4 core and what size is needed. I understand the cores are too small for the bms connections. Using simp bms
CarelHassink
Hi,
did you recycle the original cable??,
it should not be difficult,
just make something from 2x 4 matching lenghts of 1mm2 multi strand wire,
twist TX&RX, use nice 4 pole female/male connectors, and you're done
I you are about to make your own, perhaps follow instructions as per manual, page 13
and more or less do the same, but you face quite a bit of work, crimping the pins, etc
all Molex mini-fit part numbers can be found in manual, use a Engineer PA-09 to crimp the pins
  • Simp BMS Setup Manual V0.27 (7).pdf
Ford pop racer
Thank you, Im not sure what size the existing cables are so was looking for 0.5mm, if I use 1mm I can buy the colours I need and make up the 2 x 4 wires. I have the existing loom but need to cut and extend it in two places. I have superseal 10 way plugs and sockets and 5 way.
