Cheap 4-life
- Aug 3, 2020
- 380
Anyone else not able to load DIY solar forum? It says servers are down when I try. Been that way for over 24hrs
Nope not for me. It says server stopped respondinghttps://diysolarforum.com/ loads for me
later floyd
So what do I have to do. I changed the dns server number to the one in the link but then nothing would load for anything. Was I supposed to also change the ip addresss?might try a different dns server? here s a list of free one https://duckduckgo.com/?t=ffsb&q=free+dns+server&ia=answer&iax=answer
Later floyd
This web site should help https://www.lifewire.com/how-to-change-dns-servers-in-windows-2626242
Later floyd
Ps if the https://diysolarforum.com/ web site is the only site affected you may have been caught in a ban this happens when an Ip address or range of addresses are banned and if the Ip address matches xxx.xxx.xxx.(***) 256 ip block, it has been a few years since I dealt with sysop stuff
No, I used the free one you shared above, then nothing would load. I’m going to try a few other dns serversDid you get into the site?
Later floyd
I tried several different dns server numbers. Some of them worked for everything except the diy solar forum.Did you get into the site?
Later floyd
Yeah, thanks for taking the time to help. What you wrote might be above my pay grade.This is strange C4Life. Try these tests from DOS command line (or Linux Bash, if you have Linux we'll see the commands in detail again).
Before doing anything clear cache and cookies in the browser you use (all time cache+cookies) and give this command from DOS (only write the commands in the first line, without E:\>, the first command is ipconfig /flushdns AND press enter):
E:\>ipconfig /flushdns
Configurazione IP di Windows
Cache del resolver DNS svuotata.
1) Ping with DNS translation. If this ping test gives you the IP address in the first line (in bold, in square brackets) then it's NOT a DNS problem, so you can stop changing DNS:
E:\>ping diysolarforum.com
Esecuzione di Ping diysolarforum.com [108.178.31.85] con 32 byte di dati:
Risposta da 108.178.31.85: byte=32 durata=143ms TTL=44
Risposta da 108.178.31.85: byte=32 durata=146ms TTL=44
If this test doesn't work please try test n.2.
If this test gives you another IP address you are probably getting a wrong IP. Routers often cache IP addresses and if they change the router still remembers the old one. In this case switch router off and on or we can try and add the correct IP in hosts file.
2) Direct ping (no DNS involved).
E:\>ping 108.178.31.85
Esecuzione di Ping 108.178.31.85 con 32 byte di dati:
Risposta da 108.178.31.85: byte=32 durata=142ms TTL=44
Risposta da 108.178.31.85: byte=32 durata=144ms TTL=44
Risposta da 108.178.31.85: byte=32 durata=220ms TTL=44
If this ping does NOT give you then answers and the milliseconds (142ms, 143ms, etc) then you cannot reach that IP from your IP. Possibilities:
- The destination server bans your IP; in this case can you change IP? If you have a dynamic IP assigned from your provider you could try resetting the router (switch it off, count up to 5, switch it on). Check your public IP address before and after resetting the router to be sure it changed, use this site or any similar https://whatismyipaddress.com/
- You have a firewall (software one? hardware? on the router?) which blocks that destination. Or an antivirus which blocks the destination for you.
If test n.1 and test n.2 work you can indeed reach the destination IP and the problem could be elsewhere.
3) Traceroute; lets see where packets stop (in linux it's traceroute command):
E:\>tracert 108.178.31.85
Traccia instradamento verso diysolarforum.com [108.178.31.85]
su un massimo di 30 punti di passaggio:
1 2 ms 2 ms 1 ms vodafone.station [192.168.1.1]
2 17 ms 17 ms 20 ms 192.168.51.2
3 18 ms 18 ms 17 ms 192.168.51.1
4 38 ms 17 ms 17 ms 10.177.21.201
5 31 ms 29 ms 28 ms 185.210.48.42
6 31 ms 27 ms 28 ms 185.210.48.43
7 37 ms 35 ms 36 ms voda-it-gw1.cw.net [195.89.99.134]
8 43 ms 39 ms 38 ms ae6-xcr1.mlb.cw.net [195.2.28.225]
(SNIP)
17 146 ms 145 ms 145 ms be2766.ccr41.ord03.atlas.cogentco.com [154.54.46.178]
18 142 ms 141 ms 142 ms 38.104.102.102
19 144 ms 142 ms 143 ms border1.ae2-bbnet2.chg.pnap.net [64.94.32.68]
20 160 ms 146 ms 147 ms inapvoxcust-lag.border1.chg.pnap.net [64.74.106.114]
21 190 ms 154 ms 165 ms agg1.c13.r13.s101.chi03.singlehop.net [67.212.190.234]
22 146 ms 148 ms 143 ms aswg1.c02.r13.s101.chi03.singlehop.net [67.212.190.74]
23 146 ms 143 ms 143 ms diysolarforum.com [108.178.31.85]
Traccia completata.
If you see line n.1 it's my router: vodafone.station. If trace stops here it's you blocking the route to that destination. If you reach up to the end there's no problem in reaching the destination.
Ok, first lets see what happens with these tests. If they DO succeed it could be a problem with HTTPS. Questions:
- Is the date on your computer correct?
- Can you clean SSL cache on the browser?
- Can you try another browser?
After that we can try and see browsers development tools logs (open dev console with F12, we are interested in Console LOG and Network LOG).
jes
