CAN and RS485 BMS Emulated Protocols for DIY Battery to work with LV and HV Invertors - JK BMS JBD Daly 123Smart - OEM Battery
I make the interface with 2 rj45 for this battery setup:
For cascaded more then one module.
And because the battery is in the metal case and dont have access at the interface.
For open project i use the second design. that one more simply.
2 RJ45-porte på grænsefladen har CAN PIN og RJ485 identiske, du skal deaktivere CAN-funktionerne på anden grænseflade.
Lad kun RS485 kommunikere fra interface 2 til interface 1
Hvilken inverter har du??
I got the DEYE SUN-12K-SG04LP3-EU
I know DEYE use CAN port so u can make only one interface with 2 serial connections for jk.
In the Setup u need to select the Interface Name:
BT CAN / Serial CAN is for this:
RS485 CAN for the one with 2 RJ ports and with RS485 support
after u tested send me some pics with the invertor data.
Sure. i just ordered the parts for these interfaces.
So when it arrives and I made the assembly, I post pictures.
Do I need to remove connections from 2. rj45 to remove connection to CAN or is it possible to disable in software?
Do I need to remove connections from 2. rj45 to remove connection to CAN or is it possible to do this in software?
No need , from the soft u can disable any port: just select OFF on Serial / BT / CAN
Is it possible to connect display to secondary can port?
is 12c output so can connect any i2c device.
in this moment i dont implement an library for display, from my point of view i am interested to see the data remotely not to be in spot with battery.
the second reason i dont implement a display library is that jk offer 2 solutions with display from factory
but can be done
but can be done
makes sense.
Thank you for this project. When I downloaded the firmware for ESP32, it keeps restarting even when I haven't connected it to JK-BMS. I have tried both the 4.0 and 4.1 files, but the results are the same. I hope to receive some assistance.
How should the TXD2 and RXD2 (D16&D17) be connected correctly?
Thank you for your help!
"rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
1 load:0x3f400020,len:218684
ets Jul 29 2019 12:21:46"
That's a very nice project indeed. I might be interested to hook up my JK BMS to the DEYE 12kW Inverter that I have.
I have several (3) Inverters and will have > 2 JK BMS.
I have some questions :):
- Is it possible (for the JK BMS) to have both Bluetooth (for this CAN adapter) and RS485 Interface (for Raspberry PI monitoring) being used at the same time ?
- Alternatively, is it possible to have Several of these boards acting in a CAN-master and CAN-slave configuration ? Like CAN-master hooked up to JK BMS #1, then CAN-slave #1 hooked up to JK BMS #2, CAN-slave #2 hooked up to JK BMS #3, etc ?
1 - interface can communicate on Serial or with bt. u can connect raspberry pi on ttl and interface on bt.
2 - with one interface can connect to 2 jk one on serial one on bt.
3 - u can connect more then one interface 1 master rest to be slave. only the master send data to inverter.
let me understand, the device boot after the flash?
Serial on usb is 115200 8n1
And u receive some status on serial connection:
Code:
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
modeIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13924
ho 0 tail 12 room 4
load:0x40080400,len:3600
entry 0x400805f0
BMS Watchdog V 4.0
Booting
Mounting FS...
Mounted file system
Reading config file
Opened config file, size = 142
Serial Protocol 1
BT Protocol 0
Can Protocol 1
Device ID OK
*wm:AutoConnect
*wm:Connecting to SAVED AP: STF
*wm:connectTimeout not set, ESP waitForConnectResult...
*wm:AutoConnect: FAILED
*wm:StartAP with SSID:  JkBMS
*wm:AP IP address: 192.168.4.1
*wm:Starting Web Portal
Configportal running
CAN Driver installation success...
CAN Driver start success...
Serial Jk Config
ho 0 tail 12 room 4
entry 0x400805f0
BMS Watchdog V 4.0
Booting
Mounting FS...
Mounted file system
Reading config file
Serial Protocol 1
BT Protocol 0
Can Protocol 1
Device ID OK
*wm:AutoConnect
Serial Jk Config
After flashing the ESP32 with flash_download_tool_3.9.5, the ESP keeps rebooting continuously. I opened the serial port on Arduino to view the messages. I have tried flashing a different program and it works fine. I apologize for my English ability
@minhtannamdinh & @mrconstantin84 If you put your code, error logs, and configs inside of a code block, you won't get those erroneous "smiley" faces
All you have to do is wrap the portion of text by either clicking on the ellipsis
and then click the
, it will open a window to enter text, or put what ever text is highlighted in the block.
For example the above would look like:
Code:
instead of:
Send me the CHIP ID of esp from info page , to send u app key.
I would like to make JK BMSs communicate with MPPSolar inverters, but I would absolutely have no time to dig out both protocols, even less something to translate between them; and the only purpose that would accomplish is maybe a correct battery load indicator on the inverter.
mppsolar work on rs485, i dot tested on that inverter but u can try if u want,
is an pylontech or seplos emulated protocol on rs485
Hi. First of all you have to say thank you for such a project. Which JK BMS is supported? Currently I use two ANT BMS with two Lifepo4 batteries and three Soyosource inverters. But now I've bought a Solis RAI battery inverter and need CAN communication for it. That's why I came across this project. Would then buy two new JK BMS. Would the BD6A20S10P work? Thanks
