harrisonpatm
- Jan 5, 2022
- 401
I got a great deal on a bunch of nearly new prismatic LFP cells, too good to pass up, but I'm already in place with building my 14s Li-Ion powerwall. Apologies if this has been discussed earlier, but I think it could work, if....
1. Separate BMS for each bank
2. Monitor charge/discharge levels
If i keep the LFP bank between 3.0-3.5V per cell, which I believe is a conservative range, I get 48-56V at 16s. For 14s Li-Ion, that range gives me about 3.4-4V per cell, which I also think is a good conservative range. More conservative than I had originally planned for my 14s build, actually, but that hopefully just means better cycle life.
If my total system discharge drops below 48V, then the LFP BMS will/should cutoff, and the Li_ion will powerwall will bear the brunt. So, I should set the min-max voltage limits on both BMS's to parallel each other.
I think it will work, but I also haven't done it before. Any advice? Like I said, too good of a local deal to pass up, at about $55 USD per kwh, so if I can't parallel the two chemistries, I'll just stash the new purchases until I can develop a separate system.
